Has anyone had experience with this particular flow + temperature meter?  Was thinking of adding to my loop if it won't become an annoyance down the road.
SEN-FM18T10 Coolant Flow Meter with Temperature Sensor, 10K Ohm
https://koolance.com/coolant-flow-meter-stainless-steel-with-temperature-sensor-sen-fm18t10
Gaming - AMD TR 3970X | ASUS ROG Zenith Extreme II | G.SKILL Neo 3600 64GB | Zotac Nvidia 2080 Ti AMP | 2x Sabarent 1TB NVMe | Samsung 860 EVO 1TB SSD | Phanteks Enthoo 719 | Seasonic Prime Ultra Platinum 1000w | Corsair K70 RGB Lux | Corsiar M65 | 2x ASUS Rog PG279Q | BenQ EW3270U | Windows 10 Pro | EKWB Custom loop
ITX - Intel i7-10700k | Asus ROG Z490-I Gaming | G.SKILL TridentZ RGB 3200 32GB | EVGA 2080 Super| Samsung 970 Evo 1TB | Samsung 860 Evo 1TB SSD | NZXT H1| Windows 10 Pro
HTPC - Intel i9-9900k | Asus ROG Maximus XI Code | G.SKILL TridentZ RGB 3200 32GB | EVGA 1070 | Samsung 970 1TB | WD Blue 1TB SSD | NZXT H700  | EVGA G3 1000W | Corsair H150i | Windows 10 Pro
Servers - SuperMicro 846 | 2x 2695L V2 | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 24 x 6TB | FreeNas - SuperMicro 826 | 2 x 2695L | 128GB | Chelsio 10Gbe | Chelsio 40Gbe | 8 x 10TB | 847 24 x 1TB SSD | Windows Server 2019
Work - Dell XPS 15 9560 | i7-7700HQ | 32 GB RAM | 1TB NVMe | 4k dsiplay
https://linustechtips.com/topic/1137526-koolance-flow-meter/
Have the older version that just does flow.
Not really sure what problems could be had.
You have the controller already or getting that too?
https://linustechtips.com/topic/1137526-koolance-flow-meter/#findComment-13153910
The motherboard in my new build has both an input for flow and temperature for water cooling.  I'm not sure if the water flow would need the adapter or not.
My only concern would be something mechanical inside break, causing a flow issue.
https://linustechtips.com/topic/1137526-koolance-flow-meter/#findComment-13154000
Well if it did break it wouldn’t impede the flow as the fluid is already going though it. Would need to denigrate to be an issue.
Mine needs a controller as you have to select the hose inner diameter to calculate the flow right.
Also doesn’t look like the right connection for the temp probe but I’m sure could work either way.
https://linustechtips.com/topic/1137526-koolance-flow-meter/#findComment-13154062
