Hey people, I'm having a problem with my R9 280x, yesterday it was working perfectly fine, but today I booted the computer and it crashed with a white screen, which I thought was just Windows 10 being Windows 10, so I rebooted, things were looking fine, then 10mins later...
So I try again and finally the motherboard starts giving me a B2 code (MSI), so I look it up, bam, graphics issue.
The computer works fine with integrated graphics, but as soon as I pop the 280x back it, B2 code again.
We're having a very humid week with lots of rain and there was humid dust on the card, so I'm hoping it eventually works again, but I've heated it up with a hair drier for a while and still nothing.
It doesn't seem to have a dual bios switch so I can't test that, and using the 2nd bios on my MB resulted in the same thing.
My specs:
MSI Z87 MPower
Asus R9 280x DirectCUII
4x4Gb 1600mhz DDR3 HyperX RAM
Intel 4690k
PSU EVGA G1 650W
And disks.
Any sugestions/ideas of what to do? Hoping it's not dead...
https://linustechtips.com/topic/1137513-r9-280x-not-booting-with-b2-code/
Did you tried anything else? Reset bios?
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Yeah, I cleared CMOS and tried the 2nd BIOS on my motherboard. I'm not sure if there's a way to reset the graphics card firmware? It doesn't seem to have a firmware switch...
Did you tried using different pcie slot? If not start with that. It may be problem with that.
                                          WHIRO
You could try running a Linux bootable if you're worried about the firmware on the card, some Linux distros are bad with graphics drivers so I would recommend Ubuntu.
Considering the integrated graphics works I don't think the motherboard or BIOS is the problem but it's still good to rule things out.
Like I said in the title, it doesn't boot, the motherboard throws a B2 code
I’ve asked did you tried different pcie slot
                                          WHIRO
