Why does my cpu take all the load and it’s at 20% but the gpu says 0% and the fans aren’t even spinning. Is that a reason why I only get like 60fps in games cause I checked it way more often and the gpu doesn’t take any load. It’s now 120 FPS cause I am in the lobby but when I play it’s at 60fps
https://linustechtips.com/topic/1137282-not-taking-load/
If it's always locked to 60fps you probably have a frame limiter or vsync on. Check game and driver settings see if it's enabled anywhere. Also monitoring software can be wonky and sometimes not read things like gpu usage.
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
https://linustechtips.com/topic/1137282-not-taking-load/#findComment-13151919
