Hello all! I just build my first pc https://pcpartpicker.com/list/LLZFf9 and i have been having these random restarts different every time an have been have some crashes once and a while and my screen will flick on black for a millisecond. I dont know what is wrong. Any suggestions?
  • CPU
    AMD Ryzen 5 2600x 3.4 GHz 6-Core Processor
  • Motherboard
    Gigabyte B450 AORUS M Micro ATX AM4 Motherboard
  • RAM
    Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
  • GPU
    Gigabyte GeForce GTX 1660 6 GB GAMING OC Video Card
  • Case
    Thermaltake Versa H18 MicroATX Mini Tower Case
  • Storage
    Crucial MX500 500 GB 2.5" Solid State Drive
  • PSU
    Corsair VS 550 W 80+ Certified ATX Power Supply
  • Cooling
    Deepcool Gamerstorm Captain 240 PRO
  • Operating System
    WIndows 10 home
11 minutes ago, TheJooomes said:
Looking it up shows "SYSTEM THREAD EXCEPTION NOT HANDLED" is a BSOD error. What have you tried so far? What new knowledge has your research, if any, given you? Have a look at this article and tell me your findings, it's probably one of a few things in it. Good luck.
I think it is a driver issue because every time it has this issue it always is a driver related. I am going to uninstall my Nvidia drivers and reinstalling them. Thank you for replying!
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
I dont know if this will help but i have recently updated my bios for a ram issue that is fixed now.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
  • 3 weeks later...
9 hours ago, mpchorsch9 said:
I think your driver maybe outdated. If you already updated your PC drivers but the problem won't get fixed than see this solutions at Devicetricks- https://www.devicetricks.com/fix-system-thread-exception-not-handled-error/.
Michael briefly discuss the best 6 solutions for this 'Fix System Thread Exception Not Handled' problem.
Thanks for the help! I will try this tonight.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
I have ran a ram memory test and when i have disabled my xmp profile the issue has stopped. But now my ram only runs at 2311mhz instead of 3200mhz.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
I came across a similar issue with similar hardware (https://www.reddit.com/r/MSI_Gaming/comments/cfwofc/axmp_unstable_with_gskill_ram_and_msi_b450_gaming/) with the conclusion being that MSI BIOS were unstable with XMP as of about 5 months ago. The solution offered was to disable XMP.
Are you able to manually clock your RAM at stock to see if it will run without XMP?
(Ensure timing is correct for your specific RAM model! Timing specs for RAM model 'CMK16GX4M2B3200C16' can, for instance, be seen here: https://www.corsair.com/us/en/Categories/Products/Memory/VENGEANCE-LPX/p/CMK16GX4M2B3200C16#tab-tech-specs)
I will try that soon. Thanks for all of the replys!
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
Another question how to you oc the ram?
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Cooling
  • Operating System
    WIndows 10 home
To be clear, I am not saying to overclock the RAM, I am just saying to run it at the settings that specific model is rated for by manually inputing those settings. This is done through the M.I.T. section of your BIOS, a (very) brief explaination of the settings can be found on page 24 of the B450 Aurus M manual (http://download.gigabyte.cn/FileList/Manual/mb_manual_b450-aorus-m_1001_e.pdf).
Guest
