Hi, so i'm trying to get a virtual machine working on windows 10, i'm trying to make the virtual machine run Linux Ubuntu and whenever i try to start the virtual machine, it fails to start and i just get these errors. Does anyone have any advice or tips to get it working?
Failed to open a session for the virtual machine Linux Ubuntu.
Not in a hypervisor partition (HVP=0) (VERR_NEM_NOT_AVAILABLE).
VT-x is disabled in the BIOS for all CPU modes (VERR_VMX_MSR_ALL_VMX_DISABLED).
Result Code: E_FAIL (0x80004005)
Component: ConsoleWrap
Interface: IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
https://linustechtips.com/topic/1136867-issues-with-virtual-machine/
There's your problem. VT-x or VT-d is disabled. in BIOS.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
Quote
Either your CPU doesn't support VT-x or, as the message suggests, it is disabled in BIOS.
6 minutes ago, Alice951 said:
ah ok, i'll have to look into that
Most hypervisors (e.g. Hyper-V, VirtualBox) require hardware support to work. That's not an issue with the guest OS (e.g. Ubuntu). If you don't have hardware support, you can look at QEMU, but it'll be slower if you don't have hardware support for VMs in the CPU.
yeah, i dont think my hardware supports vm's as there is noVT-x in my bios, i'll look into that, thanks
What CPU do you have, then we could check. The option isn't necessarily called "VT-x" in BIOS, it may just be called something like "hardware virtualization".
My cpu is the i5 2500k
The 2500k does support VT-x (no VT-d though): Intel® Core™ i5-2500K Processor
In my BIOS, the option is under Advanced > CPU > Intel Virtualization Technology. Obviously your BIOS could be different, but look for an option that mentions virtualization. That should be set to enabled.
ok,thanks!
so i no longer get the previous error, however when i attempt to boot it i now get this error and i'm not too sure how to go about changing the kernel
This means you downloaded a 64 bit version of Ubuntu, but the VM/host has a 32 bit CPU. You would need a 32 bit version of Ubuntu (which hasn't been available in years).
Are you using a 32 bit version of Windows? Because I think that might the issue here, the 2500k is a 64 bit capable CPU.
i'm running a 64bit version of windows, could it be a setting in virtual box?
update, my apolgies i hadn't spotted this option
Does it allow you to select 64-bit? I hope so :D Then you should be good to go.
yep it did lol, however i've booted it up and i'm not sure which i should select as i don't wanna affect my actual operating system?
Everything you do here happens inside the virtual machine, so don't worry about using the whole disk etc. it won't affect your actual PC.
sorry for being a pain lol, whenever i boot its a tiny window and my resizing options are all grayed out, any tips?
That's normal during boot, because the Grub screen etc. run at a fairly low resolution and the VirtualBox tools aren't active yet. You need to install the VirtualBox guest additions and it should go to full resolution once you've signed in. There's an option to install the guest additions under "Devices" (I think). That should mount a CD in the virtual machine that has the installer on it. You probably need to install kernel header files as a dependency (I think that installer tells you what you need).
Alternatively, Ubuntu has the guest additions available in its repository, so you should be able to install them from the software center, but those might not match the version of VirtualBox you have installed.
