Are Haswell/Broadwell/Skylake etc. cores made equal
e.g. 1) a 60 core 4 x E7-8895 V2 with an 8 core turbo boost of 3.6Ghz will perform the same as a i7-4930K with a 6 core turbo boost of 3.6Ghz (both Ivy-Bridge 3.6Ghz cores) in any 6 core task?
or
e.g. 2) an i7-8086K with turbo boost and hyperthreading disabled and cores limited to 4 will perform the same as an i3-8350K (both 4 x 4Ghz Coffee Lake cores)
or for the 60 core cpus, are there windows core usage handling overhangs that lessens the performance?
Main Rig: CPU Intel Xeon X5660 (4.55Ghz @ 1.45v) / MOBO Asus ROG Rampage III Extreme / RAM 16GB Corsair Vengeance LPX1866 MHz / CPU COOLER ID-COOLING Frostflow+ 240 / GPU EVGA Titan X Hybrid (+630 core + 400 memory) / CASE Cooler Master CM 690 II Advanced + transparent side panel / SSD Crucial M550 512GB / PSU Cooler Master Silent Pro Gold 1200W / DISPLAY 1440p monitor / KEYBOARD Topre Realforce RGB / MOUSE Corsair Glaive Aluminum RGB / SOUND Creative Labs. X-Fi SoundBlaster Elite Pro / ROUTER Netgear R9000 X10 Wireless ad / OS Windows 10 Pro / DRIVING WHEEL Logitech G27
Web Server Rig: CPU 2x Intel Xeon X5680 / MOBO Supermicro X8DTL-i / RAM 64GB (2X32GB) SK-Hynix ECC LRDIMMs / CPU COOLER ID-COOLING Frostflow+ 120 + Corsair H50 AIO / GPU MSI GTX 1070 Gaming X (+250core +300 memory) / CASE NZXT Lexa S / SSD Kingston 120GB / HDD 4 x 3TB WD RAID 6 / PSU Enermax MaxRevo 1500W / DISPLAY 900p monitor / KEYBOARD Logitech / MOUSE Logitech
Actually Portable Laptop: HP Spectre x360 15' (Late 2018) / i7-8750H, 16GB RAM, 512GB SSD, GTX 1050Ti MaxQ, 4K Display / KEYBOARD Ducky One 2 Mini / OS Linux Mint 19 Cinnamon / WIRELESS ADAPTER NETGEAR A6210 USB 3.0
Bed Laptop: ASUS VIVOBOOK 15 / i5-8250U, 8GB RAM, 1TB Toshiba HDD, UHD 630, 1080P Display / OS Linux Mint 19 Cinnamon
Backup Rig: CPU Intel Xeon X3470 (4Ghz @ 1.4v) / MOBO MSI P55-GD80 / RAM 16GB HyperX 1600Mhz / CPU COOLER ID-COOLING Frostflow+ 120 / GPU Sapphire R9 270X (+150 core + 200 memory) / CASE Cooler Master Elite 343 SSD Crucial MX150 250GB / PSU Seasonic SS430-GB / KEYBOARD Logitech G910 Orion Spark / MOUSE Logitech / DISPLAY Dell SE2417HGR / OS Windows 10 Pro / WIRELESS ADAPTER
TP-LINK Archer T6E PCI-E
Server 1: DELL POWEREDGE 1950 / 2x Intel Xeon E5450, 16GB ECC, 4x 3TB Western Digital (Various) 7200RPM SATA HDD in RAID 6, GT 640 / DISPLAY Lenovo L2251p
Server 2: DELL POWEREDGE 1950 / 2x Intel Xeon E5420, 8GB ECC, 2 x 160GB SAS, GT 210
https://linustechtips.com/topic/1136615-are-same-generation-cores-made-equal/
Yep, any cores on the same microarchitecture will perform identically at the same clock speed (barring any differences in cache)
Primary PC:
PSU tier list
How many watts do I need?
Theres usually a little bit more to it than just number of cores and threads and clock speed.  As noted above, the cache  size is different with the i3-8350k being 8mb vs the 50% larger 12mb on the 8700/8086k.
Another consideration is ring vs mesh; iirc server and some HEDT skylakes use mesh vs. the S desktop counterparts that use ring, and that can affect performance as core-core latency is worse on mesh. So potentially even a core, thread, and frequency-limited professional chip may perform differently than the desktop counterpart.
Also depending on Motherboard, you will also have a RAM bandwidth difference between professional/HEDT and S desktop.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
