1. In my opinion yes.  They are the quietest and most reliable I have used.
2. Nothing other than color.
3. I haven't used any Arctic fans.  You could buy one of each and compare or look for a comparison online.
As long as you don't mind the colors, Noctua is generally considered the highest quality fans for a home built system.
https://linustechtips.com/topic/1136574-fan-advice/#findComment-13146733
1. Not really, quite a lot of price premium.
2. Redux is their previous gen designs in different shades of grey
3. Arctic fans are better value usually
Desktop benching:
https://linustechtips.com/topic/1136574-fan-advice/#findComment-13146734
If you're looking for fan recommendations, tell us what kind of features you're looking for, your specs, where you're shopping located, and budget.
https://linustechtips.com/topic/1136574-fan-advice/#findComment-13152766
