Hey guys as the title says I have a problem with my ryzen 3 1200 not boosting, first noticed it when I was gaming and the max it would clock to was 3.07ghz which is strange as it should boost to 3.4 if I'm not mistaken and 1 of the cores will only go to 1.5? Theres no thermal throttling or anything as running 240 aio water cooler temps are below 50 all the time and I've checked the bios etc for anything that may help but all out of options would much appreciate the replys guys if anyone can help
https://linustechtips.com/topic/1135974-ryzen-1st-gen-boosting-problem/
Try to reset cmos
There were problems that caused the 1200's and some other first gen chips to get stuck at 1.5.
-Moved to Troubleshooting-
Is your BIOS up to date?
Update the BIOS? Zen (not Zen+ or Zen 2) has really simple boost, it pretty much always run base clock in all core workloads.
Desktop benching:
