Hello,
I recently upgraded my GPU to a 1070 from gigabyte. From what i am seeing is that the GPU is underperforming in many games like FC5, SOTTR, Star Wars Jedi: Fallen Order, Dirt rally. here in these games on Medium to High settings the GPU is not working as well as it should do and sometimes drops the fps to below 60, its usage stays between 70%. My friend with a rx 570 and 2600 gets well above 60fps in all these titles. My CPU usage is hovering between 50-70%
My specs are:
Ryzen 2400G
Gigabyte GTX 1070 OC
G.Skill Ripjaws V 3000 @CL16
Gigabyte AX370-gaming
SSD+HDD 250+1tb
I am attaching screenshots from games
CPU: Ryzen 7 5700X Undervolted  Motherboard: B550 Aorus Elite V2 Rev1.2 RAM: G.Skill TridentZ Neo 3600Mhz CL16 32gb
GPU: MSI Mech 2X RX6600 8GB Cooler: ProLab Design AI360 LC AIO Storage: WD SN770 500gb + Sn550 1Tb + MX500 1Tb + 1TB HDD
PSU: Antec EAG Pro 750 80+G Case: Deepcool CG580 WH Monitor: Benq Mobiuz EX2510 144Hz
Mouse: G Pro Wireless Keyboard: Corsair K68 RGB Cherry MX Red Speakers: Creative Pebble V2
https://linustechtips.com/topic/1135007-low-performance-with-a-1070/
Are you using VSYNC?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Nope
14 minutes ago, Envit0 said:
Are you sure you are not using the iGPU? :)HDMI, DP plugged into the 1070? Try disabling iGPU in BIOS and make sure your applications use the 1070.
Dude, my iGpu is turned off and yes its plugged into the GPU HDMI
Anyways here is my heaven benchmark
