System
  • AMD Ryzen 3600 (Wraith Stealth CPU cooler)
  • GTX 1660 GPU
  • 550 Watt corsair PSU
  • TUF B450-plus Gaming
Problem
Cooler came with CPU  once plugged in and set up the computer says that its max is 855 rpm. While online sites say its top speed can reach up to 2700 Rpm. I just want the extra room for OC-ing as it is scaring me to over clock with these temperatures.
Question
How can i get the Rpm up if it is needed as hit idles around 60-70. what software do i need?
https://linustechtips.com/topic/1134989-fan-speed-max-problems/
The best way set a speed fan curve is through BIOS.
I am not sure if there is a setting in your's, but all MOBO in our days have this setting!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1134989-fan-speed-max-problems/#findComment-13133071
I think something might be wrong with the cooler.  Did you change any fan settings yet?
Because my CPU fan sits at around 1500rpm and I think that's the correct default setting,  and I didn't touch the fan curve at all.
Maybe you didn't connect the fan to the right header,  maybe it's defective or some weird setting somewhere.
-Scott Manley, 2021
https://linustechtips.com/topic/1134989-fan-speed-max-problems/#findComment-13133501
