While I was using my PC, the screen suddenly froze and nothing seemed to work and there was a buzzing sound coming from the headphones so I shut down the PC (holding the power button for 3 seconds) and when it restarted, there was a BSOD and the PC restarted again, after that it went it a continuous boot loop. I have tried reseating the ram, using another boot drive, resetting BIOS but nothing seems to work.
Any ideas why and how to fix it?
https://linustechtips.com/topic/1134453-boot-problems-and-bsod/
Have you tried removing all sticks of RAM except for one and maybe moving it between slots or cycling through sticks?
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/1134453-boot-problems-and-bsod/#findComment-13129077
Just now, Umar Habib said:
yes i have tried that
Have you tried to reseat CPU? This is a long-shot and often doesn't work but you can just try it in case. Try reseating any PCIe cards (including GPUs) and try booting with the absolute minimum amount of things plugged into your board.
PC:
Laptop:
Server:
https://linustechtips.com/topic/1134453-boot-problems-and-bsod/#findComment-13129094
