I just got a mouse from a friend, a really nice, barley used G502. It's the first mouse I've gotten that isn't a generic crappy piece of %&$#. But when i plugged it in, everything working except the main part, the laser.
I really want this mouse to work, what are my options? How hard would it be to fix?
(currently talking to Logitech support to see what they can do.)
https://linustechtips.com/topic/1134301-mouse-advice/
You mean the sensor's laser? None of the good mouse sensors use a laser.They all use IR led's instead.
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128209
ok, update. The mouse works! But only on my black leather wallet. Soooooooo i dont know anymore.
plus side, i learnt what the difference between a laser and optical mouse is
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128213
Do you have a glass desk? Because AFAIK, optical sensors don't work very well on glass surfaces. You should probably get a mousepad anyway though. You can find some good medium-large sized ones for $10-20.
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128220
it didnt work on my friends mouse pad either. he has a whole desk, high quality one
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128223
Oh, that's weird. You should contact logitech, they'll probably replace it with a working one. (assuming it's still under warranty)
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128228
yeah, only problem is tho i didnt buy it. it was given to me by a friend who got it off a op shop.
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128234
If you have the serial number (usually printed on the back of the mouse) it's worth a shot.
https://linustechtips.com/topic/1134301-mouse-advice/#findComment-13128240
