      So my CPU and computer in general ran very hot so I had the fan speed turned up in the BIOS. I recently got a better CPU cooler, not AIO but not stock either. It's been super loud since my fans were turned way up and I finally got around to changing the speeds.
        So I shut down my computer and restarted, booted up BIOS, adjusted the speeds for specific temps and then saved and exited. Normally it does as it should and starts right up but this time it didn't. I gave it some time, unplugged HDMI, tried it on my TV, still didn't work. So I shut it down using power button on the case and tried again. Still nothing.
        Not sure what I may have messed up or how to fix it since I can't connect a display. Not a genius with PCs but just built this myself and thought this was the best place to get an answer. Thanks!
Ryzen 5 3600
Gigabyte B450 Aorus M
Gigabyte GTX 1660 TI
Corsair Vengeance LPX 16GB 3200
https://linustechtips.com/topic/1134274-fan-speed-changes-broke-pc/
