I've recently upgraded to a RX 570 from my old GTX 950. I used to record 180fps and ~70k bitrate on OBS while not getting an over encoding error. I figured that a better graphics card would allow me to raise the recording settings and quality, but my OBS instantly gives me an over encoding error on my RX 570, on the same settings. Since the RX 570 is better than the GTX 950, shouldn't it be better at encoding as well? I've tried lowering my settings and the highest I was able to get it to without my gpu over encoding was 120fps and 30k bitrate. Does anyone know why or has had a similar issue? or is this just normal?
https://linustechtips.com/topic/1134090-xfx-rx-570-over-encoding/
Just now, Nuclear Pizza Rolls said:
I'm using amd's encoder
Can you put the 950 in there aswell? Amds encoder really isn't great. Or try using the cpu encoder. Since your using a high bitrate, id just use cpu as a low quality + high bitrate, then do a high quality compress later.
I'll try to use the cpu encoder as I've given my old card to a friend. I'll test it out and let you know
