Hey guys, I have recently built my first pc, I have got 32 3200mhz RAM with a 3800x and a 2080super, whenever I play rainbow six siege I am only getting around 180 fps with anti aliasing off, everything on low graphics, I have got the latest gpu drivers and I am pretty sure I have all the rest of my drivers installed, surely I should be getting more than 180 fps on low settings. Any help as to what I can do to fix this fps problem would be greatly appreciated.
https://linustechtips.com/topic/1133728-low-fps/
What ver driver have you installed?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1133728-low-fps/#findComment-13122564
shouldn't be a bottleneck so I would say there is some performance issues with the drivers
       Pumas.EXE has stopped responding...
  • CPU
    RYZEN 5 1600
  • Motherboard
    ASROCK B450 PRO 4
  • RAM
    16GB Corsair Vengeance LPX
  • GPU
    PowerColor RX 5700
  • Case
    Corsair Carbide 275r
  • Storage
    intel 660p 512 GB
  • PSU
    PowerSpec PS650BSM
https://linustechtips.com/topic/1133728-low-fps/#findComment-13122566
34 minutes ago, D3470 said:
Ver? I don't know what a ver driver is but the gpu driver is nvidia
https://linustechtips.com/topic/1133728-low-fps/#findComment-13122879
13 minutes ago, D3470 said:
I am using 441.66 driver type was DCH
Roll back to ver: 441.41.
The 441.66 is a creator driver and not a game ready driver, that may cause issues in games.
https://linustechtips.com/topic/1133728-low-fps/#findComment-13123008
I tried it and I am still only getting around 180 or 190 fps on all the same settings, any other ideas?
do you have 2x16 gb sticks? if you dont it will cut your rams bandwidth in half
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1133728-low-fps/#findComment-13123074
Did you use DDU to uninstall the drivers? If not, this is the way!
https://linustechtips.com/topic/1133728-low-fps/#findComment-13123085
Just now, D3470 said:
How do I do that haha
It's a software, download it, disconnect the internet connection cause windows will automatically install video drivers, run it, it is very easy to use, just select the gpu to uninstall.
When uninstall is over, install the ver: 441.41 that you download from Nvidia site (be careful by default it is set for notebook), install and you should be fine.
Don't forget to turn on internet.
https://linustechtips.com/topic/1133728-low-fps/#findComment-13123122
sadly it didn't work but I did do it using ddu
https://linustechtips.com/topic/1133728-low-fps/#findComment-13126156
any other ideas, cos I am stumped/
https://linustechtips.com/topic/1133728-low-fps/#findComment-13127115
Do you definitely have the GPU in an x16 slot? And is it running at x16? You can check with GPU-Z
CPU - Core i7 4770 RAM - 16GB DDR3 1600MHz GPU - XFX RX 470 4GB
SSD - 1TB TCSUNBOW X3 PSU - 500W Aerocool Integrator
https://linustechtips.com/topic/1133728-low-fps/#findComment-13127250
