Virtual memory issue
Go to solution Solved by Master Disaster,
The instructions in that video are frankly dangerously wrong.
Changing optimisation to Background Services over Programs will tell Windows to prioritise background tasks over running applications. This is something that should only be done on a server where most functions will be running as services. For a home use machine this change will make every application run like shit.
The creator of that video obviously has no idea what any of the changes he is making actually do and doesn't seem to understand that Virtual Memory (or a Page File) is not intended to replace RAM in games which are low on memory as its many many times slower than real RAM and if anything is likely to cause more issues than it would ever fix. A Page File will help Word if its low on RAM, GTA V though, its not going to help.
I was linked this to try and optimize gta since I kept getting random fps drops but it was playable not a big deal, and the video told me to change virtual memory which I did and after it did the exact opposite the game is now unplayable stuttering non-stop. Im wondering if anyone experienced this or has a solution. I tried to disable the virtual memory back but it still happens not sure if Im not doing it correctly or something else got messed up.
The link i was sent:
https://youtu.be/0Dj1IPd-i0Q
https://linustechtips.com/topic/1133660-virtual-memory-issue/
Main Rig:-
Server:-
https://linustechtips.com/topic/1133660-virtual-memory-issue/#findComment-13122079
System configuration -> Boot tab - Advanced settings - should look like this.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1133660-virtual-memory-issue/#findComment-13122081
Sorry missed the link. this is the solution (sorry for DK windows):
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1133660-virtual-memory-issue/#findComment-13122086
6 hours ago, Generalcap said:
Thank you both, I should stop listening to people on youtube. the funny thing is i have 16 Gb but I guess GTA probably isn’t optimized.
It's not that it's not optimized, but designed to run on computers built in 2012 or so.
Also disabling the page file (which is what people call virtual memory for some reason) is almost never a good idea.
https://linustechtips.com/topic/1133660-virtual-memory-issue/#findComment-13122945
