My control panel only shows this for some reason?
Specs:
CPU: Ryzen 5 1600
Mobo: Gigabyte B450 S2H
RAM: 2x8 GB DDR4 2400 MHz
GPU: Inno3D GTX 1060 6GB (GDDR5X 😎)
Storage: M.2 SATA 😞 240GB WD Green SSD; 2.5" SATA 240GB WD Green SSD; 500GB Toshiba HDD; 500GB Seagate HDD; 1TB Seagate HDD
Case: ZET Gaming Rare L2 BG (Black, Tempered Glass)
Case Fans: x2 DEEPCOOL RF120B (Blue LED); x1 ZET Gaming Rare SF120 (No LED)
PSU: Xilence Red Wings XN054 (700W)
Peripherals:
Monitor: Samsung UE32H4270AU 32" LED TV
Keyboard: Microsoft Wired 600
Mouse: Logitech G102 LIGHTSYNC USB
Mousepad: A4Tech X7-500MP
Audio: Behringer UM2 Preamp; Sennheiser HD 205 II Headphones; Behringer XM8500 XLR Microphone
"Gastro" Rattan & Steel Armchair from Metro Cash & Carry😎😎😎
Could you specify your system specs?
Personal Desktop":
Luna, the temporary Desktop:
Sure.
GTX 1060, Ryzen 5 1600, 16 GB DDR4 2400 MHz
Specs:
CPU: Ryzen 5 1600
Peripherals:
It seems like your gpu has not been recognised correctly. Check if you have the right drivers installed.
why are you using the windows app store version?
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
Because the control panel didn't install with the drivers from geforce experience. I tried reinstalling the drivers
Specs:
CPU: Ryzen 5 1600
Peripherals:
3 minutes ago, h4lf_gr33k said:
Sure.
I'd personally get rid of the DCH drivers since they are bloody awful.
Here's what you should do, download the latest standard driver for your GTX 1060 from nVidia website and once you have it DDU in Safe Mode.
When you're finished DDU'ing in safe mode boot to windows with your internet connection disable in order to prevent Windows Update to restore the DCH driver and then install the latest standard driver you previously downloaded.
This should fix your issue.
Edit: This method cannot be achieved using Geforce Experience but you can install it afterwards.
Personal Desktop":
Ok, will try
Specs:
CPU: Ryzen 5 1600
Peripherals:
The driver download from Nvidia includes Geforce Experience and will install it as it install the drivers.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
You are incorrect mate, there's the driver bundled with GE and the stand alone variant.
Personal Desktop":
After a fresh Windows install, i downloaded the Nvidia driver and in the installation process in the window there was the GE with a check box.....
Ok everyone, I reinstalled my drivers a couple of times and the problem magically went away. Now my control panel is fully functional.
Thanks for your advices though, I will make sure to revisit this page in time of need.image.thumb.png.488ac19a8a160e62094f35d5a77b51a6.png
Specs:
CPU: Ryzen 5 1600
Peripherals:
