I am trying to figure out how much tubing (soft), and what fittings I will need for this. What I have specd thus far is in the attached image. The gpu will be mounted vertically. Any help is most welcome.
My build specs:
https://pcpartpicker.com/user/SilentKagemusha/saved/wxbZf7
https://linustechtips.com/topic/1133386-my-first-custom-loop/
9 minutes ago, 無声影武者 said:
I am trying to figure out how much tubing, and what fittings I will need for this. What I have specd thus far is in the attached image. Any help is most welcome.
My build specs:
From what I can eyeball, you need 8 fittings as an absolute minimum, but if you intend on using the distroplate for what it's actually meant to be for, you will need 12 fittings.
Don't forget drain port either, for which you will likely need a male-to-male fitting, ball-valve, maybe some angled fittings, and one more fitting for soft tubing.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13119733
Most soft tube kits I’ve seen have 3 meters or 10 feet or so.
More than enough for a system.
Would stick to that, as the price is fair.
Also if the case can fit it, I’d add another rad. Assuming the hardware you wonna cool and if you’d like lower temps as well as less noise.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13119748
This setup is for two 360mm rads, one top, on bottom in a lian li case. :D
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13119859
Then you'll need 2 more fittings to what I said above.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13119893
This may be a newb question, but I intend to use my Corsair Commander Pro to control all six fans for the two rads. How to I get the computer to not scream at me that there is no fan on the cpu fan header? Also what does everyone think about doing a pull configuration on both of the rads and a single 120mm fan on the back for exhaust? I could also do a complete push configuration with/without the exhaust on the back. I am just concerned about cooling the MB, and want some airflow for that purpose.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13122547
Turn on the fan monitoring on the cpu header in the bios.
Saying a pull config doesn’t say what way you’re wanting to use the rad itself.
Are you doing exhaust on the top and bottom rad? I assume only the top will be exhaust, having positive pressure that way. With or without using a single fan on the back for exhaust.
The front having fans bringing in fresh Asia is more than enough for the board.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13122560
There are no front fans in this case, https://www.newegg.com/black-lian-li-o11-dynamic-e-atx-full-tower-case/p/2AM-000Z-00048?Description=LIAN LI O11DXL&cm_re=LIAN_LI_O11DXL-_-2AM-000Z-00048-_-Product , It's one 360mm rad on top, one on bottom, and an optional 120mm fan on the back.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13122563
Ok so what are you doing? Still haven’t explained that.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13122623
I have one 360 rad on top, and one on the bottom, 3 x 120mm fans on the case interior side of each rad. I am considering a 120mm fan on the back of the case for airflow. I am getting the components listed in the picture in the OP. The GPU will be mounted vertically. At first, I considered pulling air in through the top rad and exhausting it out through the bottom rad, but someone mentioned that pushing the exhausted hot air from the first rad through the second might not be the best. So, now I am debating pulling air into the case through both rads and exhausting it out the back with the single case fan, or pushing air out of the case through both rads. This will be a Cthulhu, Eldritch Horror, HP Lovecraft build with purple on black, and a sickly green LED glow. Also the MB chipset has a builtin fan. I am just concerned about airflow for the power delivery around the cpu socket.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13122747
Won’t effect the mobo either way. Would effect temps for the better. As long as the air can be exhausted properly there won’t be any issue.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13122757
Ignore it and move one? Seems trivial.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13126251
^^^ Unless you specifically need USB-C devices hanging out the front of your case and looking ugly (tis why I prefer the rear ports lol), then there's no need for it.
If you do have to have that, what mobo were you planning to get? Did you decide to go with a 3950X or no?
Gaming PC NAS Laptop Workstation
CPU: i5 12600KF 6P+4E Ryzen 7 3700X M4 SoC 4P+6E Xeon X5690 6c12t
Cooler: Noctua NH-D15S Wraith Stealth w/NF-A9 Passive Apple CPU Cooler
Motherboard: ASRock Z690 ITX/ax ASUS Pro B550M-C/CSM Apple J713AP Mac-F221BEC8 (Mac Pro 5,1)
RAM: 2x16GB 3600Mhz DDR4 2x16GB 2400MHz DDR4 24GB Micron LPDDR5 4x8GB 1333MHz ECC DDR3
GPU: Sapphire Pulse Radeon 9060 XT 16GB Radeon WX2100 M4 SoC 10C Radeon RX 5700
Storage: 1TB MP34 + 2TB P41 500GB SSD + 2x4TB IronWolf Pro in ZFS Mirror Apple AP0512Z 1TB Crucial MX500
ODD: LG WH14NS40 None LG GP65NB60 USB DVD Writer Don't know
PSU: EVGA 850W GM Silverstone SST-TX300 53.8Wh LiPo Battery Delta DPS-980BB
Case: Silverstone Sugo 14 Dell Inspiron 530S Mac16,12 chassis (13" MBA) 2009-2012 Mac Pro "Cheese Grater"
OS: Gentoo Linux TrueNAS Scale macOS 26 Tahoe Fedora Linux
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 14" M5P MacBook Pro (work) - iPhone 17 Pro - Apple Watch S11
Other Misc Devices: iPod Video (Gen 5.5E, iFlash Solo w/128GB SD Card, Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2003 Harley-Davidson Sportster 1200, 2022 Kawasaki KLR650, 1994 DR350SE
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13126299
The one that arrives in the mail today is the MSI MPG X570 Gaming Edge Wifi, and I have a 3900X
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13126313
I just bought the Aorus Master X570 by Gigabyte, and have already RMA'd the MSI board.
https://linustechtips.com/topic/1133386-my-first-custom-loop/#findComment-13126636
