Minecraft blocks not showing?
This is a problem for me now, all blocks are invisible. (well except paintings and other such things which aren't actual 'blocks'.)
How do I fix this?
I can still place and destroy them, just not see them, so everything around me is invisible, though I can see the outlines when I target them.
I reinstalled Java but it didn't help. (didn't restart pc though after that)
This is in both multi and single player and in Tekkit and Vanila.
https://linustechtips.com/topic/113325-minecraft-blocks-not-showing/
Its caused by Mantle and Java not getting along.  Someone posted this before, and I think someone linked a site that had a potential fix, but I am not sure.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
As far as I'm aware, Mantle isn't the issue. The issue is that the new drivers break OpenGL. Link to other thread with link to fix below.
http://linustechtips.com/main/topic/113309-minecarft-modpack-problem/#entry1514359
MOBO - Asus Sabertooth 990FX R2.0   CPU - AMD Phenom II X6 1055T @ 3.5GHz - Corsair H80i   RAM - 2x Corsair Vengence 4GB DDR3 @ 1666 MHz
GPU - SAPPHIRE 100362-3L Radeon R9 290 4GB Tri-X OC  Sound - ASUS Xonar DSX  PSU - Thermaltake SMART M Series SP-850M 850W
In that case I don't want Mantle. ;(
It is mantle. I had same problem, downgraded drives, and now it works
It is mantle. I downgraded and it worked again
I'm on the 14.1 betas and with the two .dll files placed into the Java folder I'm playing just fine. It's not Mantle. The two updated versions of the files broke OpenGL as that is what Minecraft utilizes.
I was only saying it is mantle, as it started to happen when the "Mantle" drivers came out, and many other topics I have read say it was mantle.
Addon Customs -
