Hi,
Planning to set my computer up for Alyx on the Valve index but I am struggling to figure out which components I want to use. With the valve being so expensive and this being my first VR set up, I want to take the budget approach for this.
I currently have this CPU and am wondering if it will be sufficient. I know valve recommends Ryzen 5. Do I need to upgrade?
CPU: AMD Ryzen 3 2200g
I know this is for minimum specs, what do you recommend?
GPU: RX 580
I am not too worried about the components below as GPU and CPU are the main drivers.
MOBO: Gigabyte AB350M-DS3H
Storage: Samsung Evo SSD 500gb
PSU: EVGA 600W B1
RAM: Crucial ballistix sport LT 2666mhz DDR4 8GBx2
This was the first computer I ever built and am still heavily researching to learn more about computer hardware. I appreciate any recommendations or advice.
Thanks
https://linustechtips.com/topic/1133191-valve-index-build-help/
23 minutes ago, Jameswf said:
Hi,
GPU: RX 580
PSU: EVGA 600W B1
Thanks
i would say that VR is more to CPU than GPU. although inr eality both are crucial. but reminding that your 2200G is only 4core and average boost clock. i would highly reccomend using ryzen 5 or equivalent. in my opinion for VR 6 core is necessary
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
https://linustechtips.com/topic/1133191-valve-index-build-help/#findComment-13118280
