Let me start off by saying I have a very limited knowledge on computers and usually have to spend a lot of time researching or watching videos to get anything done. But anyway.
So I recently built my new pc after having an older one for 5 years. When I loaded up for the first time I downloaded Minecraft for a quick test of the new system. Everything was running well with maximum settings on 1440p at around 250fps. I had the render distance set to maximum chunks, which I think is important for later on. So I don't really know a lot about overclocking but I was watching some videos on how to do it and I decided to set my cpu (Intel i7 9700k) to 5Ghz and my ram which was at 2133Mhz or something to 3600Mhz (which was what I paid for). I was running cinebench for benchmarking and got a better score after overclocking and temperatures were around the 70 mark. I didn't manually change any voltage settings but as I wasn't getting any errors I assumed everything was ok. I loaded up minecraft again the next day and saw that I was only getting an fps which varied from around 30fps to 80fps at times. When I looked straight down or up (or when I lowered the render distance) I was getting around 400fps. This is what made me think it was to do with the cpu. I reset all of my overclocking settings to default and loaded Minecraft again but I was still getting the same lower fps. I don't understand how I was able to get a solid 250fps after first playing on the brand new pc and now I cant even reach 100fps on the same settings. If anyone could help I would greatly aprreciate it.
My specs are:
CPU: Intel i7 9700k
Graphics Card: GTX 1080ti
RAM: 16 gb (2 8 gb sticks) at 3600 Mhz DDR4
Monitor: Aorus ad27qd 1440p 144Hz
Boot-up Drive: Samsung 1Tb m.2
Storage Drive: Seagate Barracuda 2Tb 7200rpm
PSU: Corsair rmx 750x
https://linustechtips.com/topic/1133188-fps-drop-after-overclocking/
A Question first. Do you know that a 144Hz Monitor can not display more than 144 FPS? So...400 FPS gives you nothing but screentearing.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
If it were me Id pull the CMOS battery on the mobo for a min, and ensure the OC settings are all reset.  Set Windows power plan to performance, same with the GPU if you use NVIDIA and see if that clears things up
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
Yeah I know that, I had vsync off on minecraft and the screen tearing wasnt really noticable. Maybe that was just because I was in awe of everything as the monitor size and fps was a huge improvement on my old pc. When I had vsync on it locked to 144Hz obviously but I was just wondering why I wasnt able to achieve the fps I had before, that's all. Not that I would need it, it's just that I'm worried I won't be able to achieve the maximum performance on other games when I test them out (I haven't tested any other games out as my wifi is garbage).
There is benefit to running higher FPS than what your monitor will display.  It's actually discussed a little in that LTT video with Shroud and the other guys.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
I Game for 20 Years on all kinds of Displays, its a Myth.
If you say so.
Hey so I tried your suggestion, and nothing changed. Although! I must've done a little oopsy as I am talking to my friend who did the majority of the building for me and he was present when we loaded mc for the first time.So... turns out we decided that what happened was that the 250 fps was when we loaded minecraft for the first time and render distance was set to default (10 chunks) and I had F3 open at this time. I must've closed F3 to look at the glorious new monitor and decided to turn render distance up to 32 chunks and not press F3. So the render distance was at 32 chunks and I must've had around 60fps so I didnt notice the lag and assumed I still had like 250 fps cos human eye yada yada yada 60fps.
TLDR I wasted your time and I'm a special little snowflake.
So sorry ?
Still read it ❤️
Enjoy your PC!
