No Post
Go to solution Solved by Ben17,
2 minutes ago, MuchSweggles said:
No. Thank you for the help!!
It was no problem glad I could help ?
I have a new build with a AMD 5 2600 Processor, B450 Tomahawk MoBo, XFX Radeon Rx 5700 8GB GDDR6, G.Skill 16GB Aegis DDR4 PC4-2400 3000MHz.
I am not getting a signal at all on the monitor when I plug it in and I am getting a boot light on my motherboard near the 24 pin collector. I have tried taking the battery out. Reconnecting the PSU. I have consulted the manual and couldnt fine the jumper on my board. I have given up.
https://linustechtips.com/topic/1132917-no-post/
Have you, mistakenly, plugged the monitor into the motherboard instead of the GPU?
The Ryzen 2600 does not have an integrated GPU so the display outputs of the motherboard have nothing to take picture from.
For example, you might have a DVI monitor, but the GPU doesn't have DVI ports (only DisplayPort and HDMI). The MBO has DVI so you might have plugged it in.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1132917-no-post/#findComment-13116119
19 minutes ago, MuchSweggles said:
I am unable to find the hdmi port on the graphics card while in the case. I'll have to disassemble it. I'll do that first thing tomorrow morning.
It should be on back of the case not inside it.
Please quote or tag  @Ben17 if you want to see a reply.
If I don't reply it's probly because I am in a different time zone or haven't seen your message yet but I will reply when I see it ?
https://linustechtips.com/topic/1132917-no-post/#findComment-13116145
The GPU should have a single HDMI and 3 DisplayPort connections.
https://linustechtips.com/topic/1132917-no-post/#findComment-13116168
I found it. But now it says "Reboot and Select proper Boot Device or Insert Boot Media in selected Boot device and press a key"
I have a usb with bootable windows 10.
https://linustechtips.com/topic/1132917-no-post/#findComment-13117174
^this is normal on a new build
Go into the bios and select the option for boot and select the usb stick also make sure that the drive you want to install windows on is plugged in (I usually unplug any other drives to make it less confusing though you can u can install windows with them plugged in)
https://linustechtips.com/topic/1132917-no-post/#findComment-13117223
I did that. And now I have windows. Thank you. But I take two steps forward and 3 steps back.
My GPU isn't working or being detected.
https://linustechtips.com/topic/1132917-no-post/#findComment-13118023
You probley need to install the drivers for it
https://linustechtips.com/topic/1132917-no-post/#findComment-13118033
Though it seems a bit strange that it wouldn't be detected in windows when your using it for the monitor?
https://linustechtips.com/topic/1132917-no-post/#findComment-13118038
Okay. Installing drivers worked. Now it can run a game. Thanks. Want 3 months of xbox?
Glad u got the problem sorted
Not sure what u mean by 3 months of Xbox though
https://linustechtips.com/topic/1132917-no-post/#findComment-13118071
Just now, MuchSweggles said:
3 months of Xbox game pass.
I don't have an Xbox but thanks for the offer though ?
https://linustechtips.com/topic/1132917-no-post/#findComment-13118095
https://linustechtips.com/topic/1132917-no-post/#findComment-13118167
