Hello I was looking to buy a Mechanical Keyboard. I'm looking to spend no more than around $150 and preferably I'd like to spend around $120.
I will be using this for both gaming and typing.
I keep hearing Cherry MX is best for gaming but I hear mixed reviews for Romer G with some people saying their the worst for typing/gaming to they're the best for gaming. Any help would be appreciated.
I was initially looking a the Logitech G613 keyboard or the K63 wireless Keyboard.
I'd prefer if they were wireless but it's not a must.
Thank you in advanced
https://linustechtips.com/topic/1132784-mechanical-keyboard-help/
Go to a store and test some out. Buying a keyboard without knowing what the switches feel and sound like is a recipe for disaster.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
That's what I've been seeing from other discussions asking similar things. I'v been to the store and have tried both the keyboards mentioned above as well as some others. I just don't really know what I should be looking for though, they feel pretty great and way better than my current keyboard. I just want to know if one is an objectively better buy or if there are certain things about different switches I should be aware of.
Also what it's like to use one for a long time.
Both are good boards compared to other, *modern* keyboards but they won't be nearly as durable as something old.
If those are your only two options I'd get the Corsair only because you can replace the keycaps later if need be.
SPECS:
these things are really subjective, objective stuff have nothing to do with key switches nor the feels, for example the media control buttons and volume scroll wheel my keyboard has.
Desktop benching:
@Jurrunio@Derrk@kelvinhall05
Thanks for the feedback everyone. The two I've listed aren't the only options I have. They were just two that I've tried and had features I liked. It seems like this is something I should do more research on by going to a store. Then are there some brands that are better than others? Better as in they're cost effective like they don't charge extra for no reason or for unnecessary features.
Anything but Razer
SPECS:
Ducky, Filco and Leopold.
