hello guys.
I just located a long lasting problem with my pc bluescreening a lot thought it was windows and it wasn't.
turnt out I had one faulty ram stick, one month after warrenty ran out, hmmmm
wanted to know if it would be possible to buy a new 8 gig kit and still use the functioning 4 gig stick.
PC specs.3570k, asus p8z77m pro, 8gb corsair vengence 1600MHz, XFX 550w, seagate barracuda 1TB, MSI 660ti, cooler master k350, cooler master hyper tx3 evo.
https://linustechtips.com/topic/113255-random-ram-in-the-same-system/
Not recommended if the ram isn't the same, but you can do it. Even if you buy different frequency RAM, your PC will run as fast as the fastest freq on the slowest ram. Also try and find ram with similar timings please :D
just thougt of getting one four gig stick and calling it a day but can the stick be another brand but the same voltage speed and latency
Been running mismatched ram for ages now, not a single problem.
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
thanks for the help now it seemed it was a usb 3 driver. i'm going to keep trubleshooting.
Yeah it can be, still thou not recommended by a lot of people.
get memtest 86 and burn it to a cd or flash drive and test your ram.
Specs: Cpu: i7-4790k@4.5ghz 1.19v Cooler: H100i Motherboard: Msi z97 g55 SLI  Ram: Kingston HyperX Black 16gb 1600mhz GPU: XFX R9 290X Core Edition PSU: Corsair HX850  Case: Fractal Design Define R4 Storage: Force series 3 120gb ssd, sandisk ultra 256gb ssd, 1tb blue drive  Keyboard: Rosewill RK9100x Mouse: DeathAdder  Monitors: 3 22 inch on a triple monitor mount
I am doing it now and 81%thrugh pass 3 and 0 errors. but how long does this take ?
4 passes is good enough to call it stable imo. I see people doing 5 passes in 5 and a half hours but when I did mine overnight I don't think I got through that many passes somehow.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
here is the ful explanation and I really need help with this http://linustechtips.com/main/topic/113436-having-problems-with-crashes-please-help/
after 1 pass its good but i do 2 just in case.
soo my memory is good then?
yes
you definitely can use different brands/speeds of ram in the same system, it will just not perform as well as if you had a matched set. It is also possible that you could run into compatibility issues too. Just some things to keep in mind.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
  • 2 weeks later...
Hello, I have a question that's been bugging my mind for a long time. I (stupidly) bought the RAM that i currently have in my rig when I built it. They are a pair of 4GB Patriot VIPER DDR3 2133Mhz. Now I want to expand the ram to 16GB but I cannot do it 1st because they're nowhere to be found and 2nd because the other good (or bad) brands are a liver worth price (over here in Argentina almost every tech thing is stupidly way overpriced). The thing is that I own a pair of 4GB Kingston HyperX sticks but different speed, timing and voltage than the Patriots. Can I use them or I can't use them at all ? I'll leave the specs of the RAMs. Can anyone help me? Thanks and sorry for my bad english :P
2x 4GB DDR3 Patriot VIPER 2133MHZ CAS11 1.5V    +    2x 4GB DDR3 Kingston HyperX 1333MHZ CAS9 1.65V (this are the sticks that I want to use to expand to 16GB)
Intel Core i7 3770k 4.2Ghz  || Asus Sabertooth Z77  || 8gb Patriot DDR3 2133Mhz || Corsair H100i  || Asus GeForce GTX680 DirectCU II 2Gb || SSD 180GB Corsair Force GS + 1Tb WD Black + 1Tb WD Blue + 1Tb WD Green
Cooler Master Silent Pro GOLD 800W  || NZXT Phantom 410 Gunmetal || 23" Samsung P2370 & 32" Sony LED TV KDL 32EX655  || Edifier "C2" 2.1+1 Speakers  || Sony MDR-V500 DJ Headphones & Corsair Vengeance 1300 Headset
Microsoft Sidewinder X6  || MadCatz R.A.T. 7 Black  || Razer Goliathus Speed Edition Fragged XL  || Microsoft Xbox 360 Wireless Controller for PC  || Samsung Galaxy S4 [i9500]  || iPod Touch 5th Gen 32Gb  || Nexus 7 [2012] 32Gb
