i was trying to copy files from another computer and it didnt copy correctly, i tried deleting the thing and it said some files couldnt be deleted, then i tried to format it and that didnt work, now everytime i plug it in i get this, yall got any solutions or is this thread just gonna sit in oblivion forever
https://linustechtips.com/topic/1132518-usb-drive-actin-funky/
Is this new?
You may have a broken drive or a fake drive.
There are many fake drives that claim to have 32gb but in reality it only has 2 or 4gb.
https://linustechtips.com/topic/1132518-usb-drive-actin-funky/#findComment-13112775
On 12/8/2019 at 6:55 PM, SupaKomputa said:
Is this new?
its a used drive, this happened when i was trying to copy a file and it was taking too long so i SAFELY cancled it and pulled the usb drive out, i went into disk management and now it reads it as raw rather than ntfs
https://linustechtips.com/topic/1132518-usb-drive-actin-funky/#findComment-13117415
If you pull a usb drive from windows without ejecting it... you can corrupt it... especially if write caching is turned on.  Turning of the caching will allow you to remove it without ejecting, but it does slow down transfer speeds.
System 1: Gigabyte Aorus B450 Pro, Ryzen 5 2600X, 32GB Corsair Vengeance 3200mhz, Sapphire 5700XT, 250GB NVME WD Black, 2x Crucial MX5001TB, 2x Seagate 3TB, H115i AIO, Sharkoon BW9000 case with corsair ML fans, EVGA G2 Gold 650W Modular PSU, liteon bluray/dvd/rw.. NO RGB aside from MB and AIO pump. Triple 27" Monitor setup (1x 144hz, 2x 75hz, all freesync/freesync 2)
System 2: Asus M5 MB, AMD FX8350, 16GB DDR3, Sapphire RX580, 30TB of storage, 250GB SSD, Silverstone HTPC chassis, Corsair 550W Modular PSU, Noctua cooler, liteon bluray/dvd/rw, 4K HDR display (Samsung TV)
System 3 & 4: nVidia shield TV (2017 & 2019) Pro with extra 128GB samsung flash drives.
https://linustechtips.com/topic/1132518-usb-drive-actin-funky/#findComment-13118784
