Hi guys!
So you may have seem my recent posts / rant status updates about my mobo (AsRock 970 Extreme4), I got it working again but when i plug my 1TB Hitachi HDD (D:\) in it just doesn't get past the AsRock Logo and the Dr. DeBug give a "99" error code. It says that it has to do with my GPU but when i disconnect my HDD and just boot from a fresly installed Windows on my SSD it just boots fine.. wut?
I don't have any other computer and my family uses Mac's.. and we don't have a extrernal HDD to USB thingy!
Please help!
(Yes, i've installed the latest Asrock 970 Extreme4 drivers!)
Thanks!
[My posts about my mobo]{
1. http://linustechtips.com/main/topic/112821-asrock-extreme-4-error-code-99/#entry1507843
2. http://linustechtips.com/main/topic/112836-how-do-i-clear-my-cmos-asrock-extreme-4/#entry1508049
3. http://linustechtips.com/main/topic/112885-how-do-i-repair-my-bios-from-usbi-fixed-it/#entry1508709
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/113240-pretty-big-problem/
Try hooking it up to different SATA ports and also try and give it to a friend to check if it's ok. Also, can you get to the BIOS or the problem pops out before you can access it? The idea is that it may look for a boot option on your HDD first.
https://linustechtips.com/topic/113240-pretty-big-problem/#findComment-1513590
yeah this pretty much. Make sure your boot drive is connected to port 0 on the mobo and hdd to 1 or anything else. Then you could change the boot priority in the bios to the ssd first if it isnt already.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/113240-pretty-big-problem/#findComment-1513609
I know my SSD is in SATA III Port 1 and the other on in 2 or 3.
When it gets stuck i can't do anything
https://linustechtips.com/topic/113240-pretty-big-problem/#findComment-1513646
