AIO Cooler orientation
Solved by tarfeef101,
Where the tubes come out of the block on the CPU should have no measurable impact on performance. Go with what fits, then out of those options whatever helps you route the tubing most easily (and/or what looks good if you care)
Serendipity1344 ·
Posted in Graphics Cards3 -
1
1
5
1
toxic_worper ·
13
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
