Hi, so I need to have ethernet up to another computer in a different room, I currently have already a cat6 ethernet cable wired to a computer, what I wanted to do is to have a splitter with one cable going into a room for a computer and the other going to the other one. I don't want a network switch, I need something small that I can just place on the hallway perhaps stuck to a wall. Now I've seen some splitters like the one below but they seem to have bad reviews and mention that only one works at a time so I was wondering if out there is a splitter similar to this that works properly
Screenshot_20191206_023746_com.amazon.mShop.android.shopping.png.8c4c84e2cb78f2abe7b22da4e6ee0a07.png
https://linustechtips.com/topic/1131571-ethernet-splitter-or-switch/
Those splitters separate the pairs, 2 pairs to one port and 2 pairs to the other. This means you can only get 100mbps off each port. You will then need a second one on the router end. The bad reviews tend to be from people not understanding this doesnt magically make 1 port on the router/switch into 2.
When I was an installer I ran into this setup all the time because people were lazy and didnt want to run two cables. I would just suggest getting a cheap unmanaged 5-port Netgear switch. They are pretty much bullet proof.
How big do you think a switch is? The average unmanaged one can be very small. Smaller than a cable modem, router, etc.
https://www.amazon.com/Ethernet-Splitter-Optimization-Unmanaged-TL-SG105/dp/B00A128S24/ref=sr_1_3?keywords=network+switch&qid=1575602404&refinements=p_n_feature_keywords_two_browse-bin%3A7306160011|7306161011%2Cp_72%3A1248879011&rnid=1248877011&s=pc&sr=1-3
4 minutes ago, Donut417 said:
Yep come to think of it even most small 5 port switches have holes so you can hang them on a wall/ceiling me personally never done that but it is an option
I use Velcro myself. This way it doesnt fuck the wall up.
