Power Supply Noise
MartinIAm
Go to solution Solved by seon123,
Coil whine? That's not an issue.
Hey, I have a Corsair cx750 and I have been using it for about 3 years so far. While my pc is idling it starts to make a weird buzzing noise for a minute and then goes away. This happens every 30 minutes to hour. Should I be concerned?
Thank you. Makes sense now.
Is it a BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB?  Or more like an RARARARARARARARARARARARARARARARARARARARA, or it could it be a JAJAJAJAJAJA?
Just kidding. You're fine.
All of the above + vrooooooooooooooooooom hahaha
