I just  cloned my 2tb hdd files onto my new 8tb hdd. But the 8tb is acting like a 2tb HDD because 5tb is unallocated. I need to convert the drive to GPT, but its greyed out on disk management. i'd need to delete the data i just cloned in order to change it  to GPT, making the cloning a complete waste of my time. Suggestions on what I should do? I want all the data from my 2tb hdd onto my 8tb hdd, but I want to have 8tb spaceimage.thumb.png.30483c9ae37319fd31c802605528cfb2.png
https://linustechtips.com/topic/1131496-help-with-cloning-problem/
You can convert MBR to GPT without* data loss using the MBG2GPT tool: https://docs.microsoft.com/en-us/windows/deployment/mbr-to-gpt
Otherwise, if it's from a data drive, I'd just delete the 8TB partitions, convert to GPT, and either copy and paste directly or use robocopy or TeraCopy.
*As with all low-level storage operations, it's not guaranteed you won't lose anything.
i just deleted it before you typed that. but now i cant even convert to GPT:
https://gyazo.com/6c2256f4c11ca9fedc05af24cb1b86ba
when i right click, change to GPT is greyed out. and i cant delete the system reserve either it wont let me
