I wanna build my first pc but I’m on a tight budget of $500 and not sure what to get I’m new to pc build and specs in general for PCs. I’m looking to run world of tanks, world of war ships and heavily modded Minecraft. Any help with picking stuff for this build would be great I would like to run an AMD cpu
https://linustechtips.com/topic/1131362-first-build/
may we know where abouts you live (the currency you are using) as that will help a lot, 500 usd is a lot more than 500 aud
https://linustechtips.com/topic/1131362-first-build/#findComment-13103732
things we need to know
1. location
2. currency
3. for 500 bucks are you willing to go used?
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1131362-first-build/#findComment-13103738
This is what you can get for under 500USD all brand new.
PCPartPicker Part List
CPU: AMD Ryzen 5 3400G 3.7 GHz Quad-Core Processor  ($129.99 @ Walmart)
Motherboard: ASRock B450M PRO4 Micro ATX AM4 Motherboard  ($59.99 @ Newegg)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-3200 Memory  ($59.99 @ Newegg)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  ($63.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($49.99 @ Newegg)
Case: Cooler Master MasterBox NR400 (w/ODD) MicroATX Mid Tower Case  ($64.98 @ Amazon)
Power Supply: EVGA BR 500 W 80+ Bronze Certified ATX Power Supply  ($43.98 @ Newegg)
Total: $472.91
Generated by PCPartPicker 2019-12-05 09:19 EST-0500
If you are willing to go used, pickup a used Ryzen 1600 or 2600 and an RX 580.
https://linustechtips.com/topic/1131362-first-build/#findComment-13103745
Hello,
If it's USD, here is an entry level gaming PC :
Otherwise as stated above, buy used :)
https://linustechtips.com/topic/1131362-first-build/#findComment-13103748
could go something like this
im guessing you would use ethernet, you could add a 1tb or 2tb drive if you can increase the budget a tad
Total: $472.91
this is also another option that you could go with as mincraft mods can tax the cpu quite hard
https://linustechtips.com/topic/1131362-first-build/#findComment-13103750
https://linustechtips.com/topic/1131362-first-build/#findComment-13103761
9 minutes ago, Plouffe said:
You did ?
you did good though, chin up mate, 500usd is quite hard to build effectively in
9 minutes ago, boggy77 said:
was going to say you swopped in with the victory but i do believe he will make more use from 16gb of ram, as he could run stuff in the back ground, minecraft mods on top (some have weird ram usages). personally i wouldnt recommend 8gb in a build in late 2019, even if it needs to go back a little on storage (not sure about adding ram but adding a hdd later to me seems easier)
https://linustechtips.com/topic/1131362-first-build/#findComment-13103772
3 minutes ago, WickedStarfish said:
you did go though, chin up mate, 500usd is quite hard to build effectively in
yeah, it's really between ram and storage. i guess it makes sense to go for 16gb ram and 240gb storage and then get a 1tb hdd later.
https://linustechtips.com/topic/1131362-first-build/#findComment-13103778
