Need help with RAM
Go to solution Solved by SavageNeo,
1 minute ago, ZWELINHTET said:
Thank you. I would like to do that too.
But there is no stock for those that I can get my hands on within 2 days time.
I'm sure I'll buy those 3600MHz C14 RAMs later
but what I want to know as of this moment is that
"is that possible to use 2 of single 32GB RAMs" on my motherboard.
Yes, but whats the point. My windows uses under 4 gb of ram, and my games use under 10gb of ram so i stll have 20 gb left in my system.
and i have 32gb of ram
I need 64GB of RAM for some stupid reasons and I'm looking at this Corsair Vengeance LPX 32GB DDR4 3200MHz C16.
I already have Gigabyte X570 Aorus Pro and Ryzen 7 3800X and 2080 Ti.
Can I use 2 of those RAM as a total of 64GB or do I need to buy "32GB x 2" or "16GB x 4" RAMs?
I really need a total of 64GB and I'm not sure if it's okay with 2 of single 32GB RAMs...
Please help...
https://linustechtips.com/topic/1130155-need-help-with-ram/
Please help...
Get 32gb trident z neo 3600mhz cl14 rgb instead. With cl14 and 3600mhz speed you get heck of a lot more performance than with cl16 3200mhz.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1130155-need-help-with-ram/#findComment-13094446
https://linustechtips.com/topic/1130155-need-help-with-ram/#findComment-13094492
https://linustechtips.com/topic/1130155-need-help-with-ram/#findComment-13094499
yeah .. that's what I'm thinking too.
I'm told this pc might be using for movie editing (or not) and the RAM need to be at least 64GB.
This is where my confusion goes away. Thanks ❤️
https://linustechtips.com/topic/1130155-need-help-with-ram/#findComment-13094512
Hey @ZWELINHTET
Your Zen 2 (Matisse) CPU does support DDR4 up to 3200MHz, and the AMD X570 Aorus motherboard memory support list does also show support for 32GB RAM density DIMMs. However, the Crucial branded memory on the memory support list only runs at 2666MHz. So, you may find that the 3200MHz speed of the Corsair DDR4 branded memory may not be achievable without a supported BIOS update.
If there is support for the Corsair Vengeance DIMMs, and I suspect that there is, buy a matched pair and insert them into the same coloured slots, for example, DDR4_A2 and DDR4_B2 to enable Dual-channel.
I hope this helps ☮️
Those who deny freedom to others deserve it not for themselves (Abraham Lincoln,1808-1865; 16th US president).
https://linustechtips.com/topic/1130155-need-help-with-ram/#findComment-13094578
