Hi, I want to mount a gpu inside a T710 dell but it won’t fit... I wanted to mount it vertically but the pcie express slot is on the upper part of the case, so every vertical bracket seems to be wrong for my case. Do they work anyway or there is a specific gpu vertical mount for this “contrary” scenario?
https://linustechtips.com/topic/1130048-vertical-mount-gpu/
https://linustechtips.com/topic/1130048-vertical-mount-gpu/#findComment-13093730
17 hours ago, Pittu2752 said:
The card still has to arrive, but I think it won’t fit... can I use it flipped?
i mean a pic of the case and slot would do wounder in stead of just guessing....just saying. imo just get a better case there cheap or even free. i mean there are many many Vertical mount GPU. there also ones from mnpctech that attache's to a fan but comes at a cost...
on my pc i got a pci slot form mountain mods and attached it with 90. later on i moved it to the back.
https://linustechtips.com/topic/1130048-vertical-mount-gpu/#findComment-13097304
https://linustechtips.com/topic/1130048-vertical-mount-gpu/#findComment-13097581
