Interesting Problem: GTX 1080
Solved by Will i am,
33 minutes ago, The Torrent said:power supply transformers hold charge in caps for some time its probably that.
36 minutes ago, NumLock21 said:So DP2 and 3 isn't working at all. The PC has to be off first. Monitors are plugged in, then PC turns on so it detects correctly.
Some other options can try out is, remove the card and plug it back in or try another PCIe x16 slot (if your board has them).
Thank you for your help guys I think a mixture of a fresh install of driver software and turning everything off and plugging it back in solved the issue.
I guess the simple solution worked...
