@Mightye777 I had no idea that the prices were higher in Australia... I thought they would be around the same price both here in America and Australia... that's my bad sorry about that. But I'm glad that you found a build in your price range!
@Mightye777 As far as the cooler master cases go... some of the other people helping you out might think I'm wrong for saying this... I just like to start people with easy yet powerful (for the budget) parts for building purposes especially when it's for first time builders. The first time I build a PC... I was using a case that wasn't an i series case from NZXT, and for the life of me I couldn't figure out the front panel connector pins - what order they went in, etc. there were like no tutorials online, so I ditched that other case and got the H500i the H10i (newer one but has the same features). There was a hole plug for the front panel pins... something that took me about 4 hours to figure out on my first build (to be honest I still am pretty bad at doing it today) took me like 1/5 a second to just plug in... because it only goes on one way.
I know this is a really long answer to your question but as far as building goes I love the H510i and i series cases from NZXT not only because of the front panel connector plug, but because of the pre mounted standoffs and the RGB is pretty solid too. But feel free to get whatever you want I checked the Australian Amazon and it is more expensive. Your case could have the connector for the front panel but I'd double check. Hope this helps.
