Wattage for liquid cooling
Solved by Husky,
The amount of wattage that a cooler uses whether air or liquid is very minimal compared to the other components in the system. I can't give you can exact number but I can say that it shouldn't make a difference in terms of power delivery or what PSU you should get in most cases.
Featured Topics
Crash The Noise ·
1
Shadow1789 ·
Posted in Cooling3 -
7
4
2
10
