Yes
it's labeled on the PSU itself
Desktop benching:
10 minutes ago, BulletSingularity said:
Is it that “Peripheral and SATA” labeled one the 6-pin correct? Or do you remove the extra 2 on the 6+2 connector for the second one?
Corsair PSUs generally have two types of ports (in addition to 24-pin ATX) - Peripheral & SATA and PCIe & CPU. You should be using the latter.
And no, you don't need to remove the extra 2 pins. You can use one 8pin cable and one 6pin cable or if you can't, just leave them hanging.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
And no, you don't need to remove the extra 2 pins. You can use one 8pin cable and one 6pin cable or if you can just leave them hanging.
Ok thank you I just wasn’t sure which one
images?q=tbn:ANd9GcRdsjTRGmswKsMs4MpB34k
You use the whole plug for the 8pin and remove 2 pins for the 6pin connector yes.
Desktop benching:
1 minute ago, BulletSingularity said:
Lol my bad I was just making sure not to mess anything up
because it clearly says PCIe 6+2 on the PSU, below the 8pin sockets
Desktop benching:
