Currently I’m having troubles with FPS in most of my games, where I don’t see a considerable increase in FPS when I decrease quality. I’m testing my FPS on rainbow six siege.
specs:
- gtx 1080
-i7-7700k @ 4.20ghz
32gb ddr4 2400
i’ve tested to see if it’s the temps, cores and I’ve ran all diagnostics from my manufacturer support page. Every result says it’s running fine but when I check any benchmark videos with the same setups, they’re averaging 200+ FPS, where I usually get 130-160fps. Not much of a difference when you think about it, but usually I play on low quality, and still happen to get jumps down under 100 FPS in more chaotic situations.
please help! Thank you so much.
https://linustechtips.com/topic/1128488-really-need-some-professional-help/
I guess that's 1080p or even lower. Your CPU is a bottleneck.
The solution, since you already do have a card meant for 1440p gaming, is to get a 1440p monitor or use Nvidia VSR to play on higher than 1080p.
The alternative would be upgrading the platform. Meaning the CPU, motherboard and maybe even RAM if you decide on Ryzen.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
install msi afterburner in game OSD and check % of cpu usage and gpu usage, in some areas you can see botleneck or if someting is wrong also frametimes.
also disable bloatware options of win 10. and get default clock of the cpu to see diferences.
So basically, if I play in 1080p no matter what I’m being bottlenecked from the cpu? If I went the route of 1440p monitor, I’m having to lose the ability of my 240hz monitor(I know it’s not noticeable, just already spent the money)
but, considering that I’m not too worried about quality but more on FPS and smoothness, the mobo and cpu would be a better path?
