Reinstall Windows.
Also what is it with people updating BIOSes for no reason then fucking up their mobos. Seriously.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1128405-help/#findComment-13083085
1 minute ago, Vainix said:
is there a way i can keep my stuff
Just copy it to an external drive or Google Drive or something.
SPECS:
https://linustechtips.com/topic/1128405-help/#findComment-13083093
2 minutes ago, Vainix said:
But i cannot boot my pc at all
How are you getting BSODs if you can't even boot your PC. There's nothing to crash if you can't get into your OS.
SPECS:
https://linustechtips.com/topic/1128405-help/#findComment-13083098
So what do i do when i get to the bsod to save files
How are you getting the BSOD? Can you even get to the lock screen or desktop?
Maybe use an external Linux USB. Should work unless your drives are encrypted.
SPECS:
https://linustechtips.com/topic/1128405-help/#findComment-13083103
it goes windows screen and then straight to bsod no lockscreen
Then do what I said with the external Linux USB. You'll need another computer to create it, but even a library PC will work.
Hell if you have a rooted Android phone there's an app called Drivedroid that you can use to host a boot image on your phone and make it act like a USB drive.
SPECS:
https://linustechtips.com/topic/1128405-help/#findComment-13083111
