[HELP] RDR2 ultra settings look awful? low res textures
Hey guys,
So I'm just wondering, does anyone else have really bad textures? the ground, rocks, and trees are very low res. I'm playing poker atm and the cards are blurry as hell. I have a mix of settings throughout and have been messing around with the settings trying to sort this out to no avail. If I change my textures from ultra to low, and restart they look the exact same and my FPS doesn't change. I've tried medium and high and again, no change.
Image 1: https://prod-cdnugc-rockstargames.akamaized.net/ugc/rdr2photo/iMje3u0qTkqGQduY6hCgQw/0_0.jpg
Image 2: https://socialclub.rockstargames.com/photo/rdr2/K2ENTz--zkeLTWXDkLbceA
Image 3: https://prod-cdnugc-rockstargames.akamaized.net/ugc/rdr2photo/7rpi0RscI0atN0-Y_bzDWQ/0_0.jpg
These images are with Ultra textures
Also, does anyone know how to change the resolution using Vulkan GPU API? I can change to DX12 and change res, then change to Vulkan but that just makes the game shit itself and a restart just reverts it to 1080p if Vulkan is selected. Is it just not possible to use Vulkan at any other res than 1920x1080?
Thanks in advance!
1 minute ago, Saksham said:
check the driver settings
Which settings? I have tried 441.12, 441.20, and am currently on 441.41 Nvidia drivers, none of them seem to have made a difference. Within both GeForce experience and the settings file in documents/rdr2/settings it says that my textures are on Ultra but I refuse to believe that those textures are ultra haha.
Ultra settings is to much for the game. With my 2080ti on everything ultra I get low 30s for my FPS. Drop everything to high and more than double your FPS easily.
"Black Out"
Dedicated Streaming Rig
well the issue is for me low, medium, high and ultra all look the same, and I'm guessing they all look like what low should look like. It's like my settings menu is just there for looks and nothing actually changes.
  • 3 weeks later...
whats your resolution? I play on 1920x1080 monitor with ingame resolution 2715x1527 (yes, this is no joke).
Iam suspicious you are playing with TAA on.
For some reason on FHD and lower TAA makes the screen looks like oil painting. On 1440p and higher it makes it looks really good. Try higher the ingame resolution - GPU will downscale it anyway but with TAA it helps alot!
  • 1 year later...
I dont know if you still have that problem but for me it was the TAA Sharpness. If you put it on full, everything will be blurry and shadows will be pixelated. Move the bar all to the left and then press the right arrow exactly 27 times for the perfect setting
Guest
