they are the same board with more connectivity/features, so pick yourself.
Desktop benching:
https://linustechtips.com/topic/1127731-mobo-advice/#findComment-13078075
VRM the same on all of em?  The big thing about the tomahawk iirc is it’s got really beefy VRM for a b450 board.  Enough to run some large CPUs.  If it’s all the same though just pick the features you want.
https://linustechtips.com/topic/1127731-mobo-advice/#findComment-13078109
5 minutes ago, HereticCommando said:
Oh okay, I was wondering if there are "under the hood" differences that I'm not seeing
VRM itself is the same, but heatsink on the A Pro is smaller than the Gaming Plus, which is smaller than the Tomahawk. Not by much though, so performance is largely the same.
Desktop benching:
https://linustechtips.com/topic/1127731-mobo-advice/#findComment-13078117
