What audio equipment do I need for an XLR mic + high impedance headphones
Solved by rice guru,
audio interfaces have a built in DAC amp but often modern consumer interfaces like a scarlett or your cheap behringer one wont have one thats too powerful or overall clean . you should be able to use the xbox as a source plug it into your mixer and listen to it through your pc personally not sure how mixers should be setup I don't have one myself.
a mixamp is just a shitty DAC/amp that comes with Astros. you sould run a separate DAC /amp and a mizer for you mic no proble. or you can grab a relatively easy to drive headphone and plug it into a interface like a scarlett
