Hi there. I'm building my first system and I've decided to use ryzen 5 3600. I've managed to buy on sale MSI B450 Gaming Plus Max. According to MSI page it supports RAM up to 4133 MHz but if you get to the specification it does not specify 3600 MHz. Below I've listed my questions.
1. Taking into account that specification does not list directly 3600 MHz as supported frequency should I buy ram with lower frequency and lower cl (e.g. 3200 MHz CL14)?
2. Have anyone of you actually run this mobo with 3600MHz ram?
3. Should I consider returning this mobo and buying something different? If I should then what are your suggestions for different board?
https://linustechtips.com/topic/1127119-help-on-matching-ram/
1) buy either 2x8gb 3600mhz cl 16 memory or 2x8gb 3200mhz cl 14 memory. The 3200mhz cl 14 memory is very expensive.
2) if is supports up to 4133mhz it will support 3600mhz
3)go with that mobo
3600mhz memory: https://www.amazon.com/G-Skill-Trident-288-Pin-PC4-28800-F4-3600C16D-16GTZNC/dp/B07WVT8SGF/ref=sr_1_1?keywords=trident+z+neo&qid=1574618233&sr=8-1
3200mhz memory: https://www.amazon.com/Corsair-CMW16GX4M2C3200C14-Vengeance-PC4-25600-Desktop/dp/B07G8Q7QPY/ref=sr_1_3?keywords=3200mhz+c14&qid=1574618271&sr=8-3
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1127119-help-on-matching-ram/#findComment-13073368
Look here on the boards QVL it supports 36000Mhz.
https://www.msi.com/Motherboard/support/B450-GAMING-PLUS-MAX#support-mem-19
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1127119-help-on-matching-ram/#findComment-13073373
