Hi, my mobo is not powering up when my graphics card is installed, if its not installed, mobo would power up. Mobo has a tinsy bitsy damaged pci e, so i thought mobo has the issue, my graphics card is 1000 bc old and had underwent several repairs, so i thought it is the issue, what do you think?
(image is the tinsy bitsy damge on pci e)
https://linustechtips.com/topic/1127106-which-has-the-issue/
ummmmmmmmmmm.... the PCIE dmg and probably the mega amounts of dirt and dust....
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1127106-which-has-the-issue/#findComment-13073258
Just now, Eyyyyyy said:
can i change pci e slots? (sorry, a newbie on this stuff)
about the dust, I hadnt really touch it years ago.
Clean the PC first before you do anything.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1127106-which-has-the-issue/#findComment-13073289
cleaned. tnx for the response btw. whats next?
once its cleaned, try again in the main PCIE slot. If still nothing, then put it in the next PCIE slot down.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1127106-which-has-the-issue/#findComment-13073393
