Ok so i have a 500 euros budget ( 550 dollars ) and want a new pc for gaming and, possibly, recording or streaming,
I dont need a new case and storage because i already have that and i have keyboard and mouse.
If you could leave some suggestions. My aim is to play 1080p 60fps.
Thanks
https://linustechtips.com/topic/1126780-help-for-new-build/
Not sure what games you are playing, nor your country. But this should fit in your budget of 550USD.
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($114.99 @ Amazon)
Motherboard: ASRock B450 Pro4 ATX AM4 Motherboard  ($79.99 @ Newegg)
Memory: Team T-FORCE VULCAN Z 16 GB (2 x 8 GB) DDR4-3200 Memory  ($54.99 @ Newegg)
Video Card: EVGA GeForce GTX 1660 6 GB SC ULTRA GAMING Video Card  ($199.99 @ Newegg)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($44.99 @ Newegg)
Total: $494.95
Generated by PCPartPicker 2019-11-23 14:09 EST-0500
If you don't need a PSU, you can probably get a 1660 Ti
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13071175
I'm assuming you're in Germany. If not, I'll go make up another list.
CPU: AMD Ryzen 5 1600 3.2 GHz 6-Core Processor  (€99.90 @ Caseking)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  (€77.80 @ Alza)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  (€58.89 @ Mindfactory)
Video Card: MSI Radeon RX 580 8 GB ARMOR OC Video Card  (€169.99 @ Amazon Deutschland)
Power Supply: Xilence Performance A+ 430 W 80+ Bronze Certified ATX Power Supply  (€40.70 @ Amazon Deutschland)
Total: €447.28
Generated by PCPartPicker 2019-11-23 20:53 CET+0100
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13071267
Total: €447.28
I know its off topic but, is it true, the legendary LienusLateTips?
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13071272
I'm not the actual Linus, but I live shockingly close to him, have two i7s signed by our lord Dennis, and wrote the PSU Tier List here in the past.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13071341
Can I get a little help please?
I want to upgrade my son's pc for better gaming he is now playing the likes of Assassin's Creed etc but it is clearly underpowered and would like to know an order of priority of which components to upgrade first, plus what is the best value for money (not high end) options.
He has (as per screen capture attached):
i3 / 7100/ 3.9GHz
8GB 1066GHz 1920 x 1080 @ 60Hz
GTX 1050
Some dodgey Chinese fan
Thanks
Jas
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13071622
i3 / 7100/ 3.9GHz
GTX 1050
Thanks
Jas
Make your own thread, don't piggyback off someone else.
The first thing you'll want is a new CPU and GPU. It might be worth it for you to upgrade motherboards too, maybe not.
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13071985
Total: $494.95
I am from Italy so I cant buy from Newegg but you went really close to what I originally thought out before going out to ask on the forum because i wasnt sure i was getting all the value for my money but thanks!
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13073007
Total: €447.28
You were close with the country, I am from Italy but thanks for helping!
https://linustechtips.com/topic/1126780-help-for-new-build/#findComment-13073009
