Hello everyone,
     Is there any way to bind keys on the numpad so that the binds will only be applied if numlock is off? For example, If numlock is on, pressing the numbers will type the respective number(if 8 is pressed, '8' is typed), but if numlock is off, pressing 8 would turn my volume up (the default binding for 8 with numlock off is the up arrow key).
Thank you
https://linustechtips.com/topic/1126754-keydominator2-help/
