8 minutes ago, Jacobio said:
I have low resolution shadows in every game even though every setting is set on max. Could broken video card cause that? I was overlocking it and i'm afraid that i broke something. I have the latest drivers
Usually the settings for shadow are set to low because it's one of the most demanding settings, meaning lowering your FPS a lot when it's set to higher quality.
https://linustechtips.com/topic/1126488-low-resolution-shadows/#findComment-13068951
But i have them on max setting and they're still low res
https://linustechtips.com/topic/1126488-low-resolution-shadows/#findComment-13068979
