Hi,
I wanted to get 2 Arctic Prizm 120mm coolers for my new case
but it seems each fan has 4-pin fan connector and 3-pin RGB
connector. I have 2 questions:
- Does that mean I will need to buy a fan controller/hub to connect those fans?
In that case I would be better off buying a pack of 5 fans that includes
fan controller/hub?
- If I connect only 4-pin part and leave 3-pin part hanging, will fan
still work?
https://linustechtips.com/topic/1126403-case-argb-fan-question/
10 hours ago, Wigit said:
So if im correct, when a mobo has no rgb headers and no hub you get no lights at all or lights with no/limited control?
That would no lights and just fan control.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1126403-case-argb-fan-question/#findComment-13070174
16 hours ago, glenalz81 said:
If you don't have an argb header on the motherboard or a controller then you will need some sort of hub to control the fans.
Can you have a look on this motherboard and let me  know if you see ARGB header there?
The motherboard is Gigabyte B450 Aorus Elite.
And if I have say, 3 PWM + ARGB fans, does that mean I will need 3 PWM + 3 ARGB header slots on motherboard?
https://linustechtips.com/topic/1126403-case-argb-fan-question/#findComment-13070282
