20 minutes ago, nhess said:
Hey guys I have a gaming headset and the cords are too short and keep super close to the desktop. Can someone point me to which extension cable to buy?
I assume its dual 3.5mm cables because you said "cords".
Here you go:
https://www.amazon.com/Plugs-2-Microphone-Extension-Computer-Headphone/dp/B079MBYF3X/ref=sr_1_9?crid=1B6O6RSD0LLU4&keywords=headset+extension+cable+mic+and+audio&qid=1574445038&sprefix=headset+extension+cable%2Caps%2C138&sr=8-9
Ok, this might be a bit of a long work around but it worked for me:
3.5 mm jack to USB 2.0 converter (get the name brand like Corsair or USBtech). USB converter to PCI converter and drive it direct from the motherboard. Best quality ever. I can really hear the enemies behind me! Make sure you get the common earth 3.5 dual channel braided cable, atleast 1-2m lenght. Un-common earth cable can lead to distortion and un-braided cable will lose some frequencies.
JK: any female-male cable will do fine!
