 Helllo i have my computer now which you can find here and i'm wondering if i could just grab a R9 270X and throw it in my computer with my R7 260X and then just use the 270 for mining and use my 260 for gaming.... i'm not sure if there capability but can someone tell if it will be better to buy cheap system parts then put the R9 270X or just use myt computer that i use now and put the 270 in there...????
please help
https://linustechtips.com/topic/112632-graphics-card-for-mining/
What are you mining? BitCoin? LiteCoin? ... DogeCoin?
CPU: Intel Core i5 4670K @ 4.4 GHz Motherboard: MSI Z87 G43 RAM: 8GB Corsair Vengeance 1600MHz GPU: EVGA GeForce GTX 980 Superclocked Case: Bitfenix Ronin
Storage: 120 GB Samsung 840 series SSD, WD Green 2TB PSU: XFX core edition 650W Display(s): ASUS VE228H 21.5IN 1080P Cooling: CM Hyper 212+
Keyboard: Microsoft P.O.S Mouse: Corsair Raptor M40 Sound: Sennheiser PC 330 Headset
https://linustechtips.com/topic/112632-graphics-card-for-mining/#findComment-1505807
Probably bitcoin
You Would want to go with an AMD Card so 280x/290x/7970/7950 what ever you can find that is cheaper.
Christian and Proud of it
Please read the CoC        My Build Log
https://linustechtips.com/topic/112632-graphics-card-for-mining/#findComment-1505826
Probably bitcoin
Yeah, no. There is no way that will EVER be profitable. People have farms of 250+ R9 290s for that.
If anything, mine Dogecoin. Even my 770 is fine for that.
https://linustechtips.com/topic/112632-graphics-card-for-mining/#findComment-1505845
doge is worth nothing... i was just mining dogecoin with my mac and got some of them... but there worth nothing and probably only making 130 a year
https://linustechtips.com/topic/112632-graphics-card-for-mining/#findComment-1505862
This is what I get with 300Kh/s on Middlecoin.com
Mind you I don't mine there every day but do this for MUCH better results
http://www.middlecoin.com/reports/1DMnRjruxtHRp3Tid1JBTLCi4aSh2QDsWQ.html
https://linustechtips.com/topic/112632-graphics-card-for-mining/#findComment-1505881
I don't see why not to mine bitcoin and to mine LTC
bitcoin and litecoin are not the same at all. One is sha-256 mining, the other is scrypt mining. litecoin and other scrypt mining currencies are asic resistant, bitcoin is not. And even if you're going to mine litecoin you aren't going to get jack these days with a single 270x.
https://linustechtips.com/topic/112632-graphics-card-for-mining/#findComment-1507649
